It is currently Sun Jul 20, 2025 4:00 pm
PostPosted: Thu Jan 25, 2007 6:23 am
Does anyone have a Martin with a vintage "V" neck I can get specs from. I played a MArtin OM-18V 14 fret I really liked but did not mic. I could use the depth measurement at the nut, 5th, 7th and 10th. Once I set the depth, I'll just "V" the sides.
Sound about right?
PostPosted: Fri Jan 26, 2007 2:17 am
1929 0-18, 12 fret, 1 7/8 nut width, flat fretbaord as well. 1st fret - .840, 9th - .965, 10th - .990. Its basically straight line from the 1st to the 9th, then gently curves up to the heel.
PostPosted: Fri Jan 26, 2007 2:06 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
This is from Martin site
At fret1   and 10 If you scale them to the actual width then you will have an actual template
Martin Neck ProfileAlain Lambert39108.9216087963
